I have made a sheet set that I use, BUT when I add a sheet or save an existing sheet with a new name and edit the fields thru the SSM, It doesn't take?
I have to edit the fields in the drawing by right clicking the field, pick edit field & then point to the correct file in the field editor box.
Why don't my fields update after I edit from right clicking the file in the SSM?
This is also true when I add a new sheet, which is the template I created to use for this purpose.
The only thing that works correctly are the fields, drawing file name & the fields that are Sheet Set controlled.
Not my custom fields which are sheet specific?
Any help is GREATLY appreciated!
Thanks, Mark
