Thread: Mapexport command
    2008-03
    Ogden, Utah
    26
    Default Mapexport command
    Let me preface this by saying that I have never used ArcGIS. I am trying to export some polygons to be used to reference some ownership plats in ArcGIS. My GIS guy is telling me there are to be six files exported. He says "The shapefile usually consists of 6 files, .dbf,.prj,.sbn,.sbx,.shp,.shx" I'm having trouble getting all six files, when I export the map data, I only get four. I'm not sure what I'm doing wrong. He also wants me to attach data to the files that uniquely identify each polygon. I have no idea how to do this. If someone can explain the process to me as if I were a five year old I would appreciate it. Seeing that I have no background in ArcGIS and never use the mapping functions in autocad, I'm having a tough time finding instructions basic enough for me to follow. I'm using Civil 3D 2012. Thanks in advance!
    Cairo - no, not Illinois
    5,069
    Default Re: Mapexport command
    are your 'polygons' MPOLYGONS ? Closed plines? open Plines?
    2008-03
    Ogden, Utah
    26
    They are closed, and I check the box to treat closed polylines as polygons.
    2008-03
    Ogden, Utah
    26
    Well, I got it figured out. Still not even sure what I was doing wrong before.
    TN/KY Area
    1,640
    Well first off your GIS guy is a little off, there only need to be three files, .shp (geometry) dbf (data) and shx (sort of a link between the other two) you may also get the .prj which is the projection file if you have a coordinate system assigned to the dwg. The sbn and sbx files are created by ESRI and used for it's own use.
    As for getting the data to export with the geometry if you still need help ask.
    2008-03
    Ogden, Utah
    26
    I think I finally got it. Thanks!
  1. 2014: Why is the MAPEXPORT button gone in 2014?
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2016-08-10, 09:39 AM
  2. 2012 coordinate conversion during mapimport or mapexport
    By dmingo in forum AutoCAD Map 3D - Import/Export
    Last Post: 2013-09-20, 02:19 PM
  3. 2012: Where can I find the equivalent of or the file itself in C3D - MapExport.ini??
    By unkleroy in forum AutoCAD Civil 3D - General
    Last Post: 2013-02-22, 09:07 PM
  4. Replies: 0
    Last Post: 2012-05-11, 09:12 PM
  5. Problem in mapexport command with epf.
    By hildevasco429126 in forum AutoLISP
    Last Post: 2010-11-12, 10:55 AM
