Results 1 to 1 of 1
Thread: Route problem in Tube and Pipe run
    2014-05
    Question Route problem in Tube and Pipe run
    There is a problem in the route, since its color has changed to brown, and i want to locate the issue. Other problems, coming along with this, are while editing the route the tube does not hide even after clicking display routes only option and also any new sketch/line in the route does not produce any pipe segment in this particular route.
    Also the pipe segments and fittings in the browser have red update option which never updates and when pointed shows update deferred message and also the segments and pipes does not get deleted. I think it all relates to the route problem but the issue i route is first to be located.
    Any suggestions on this issue are welcome.
    Thanks
    imsb
  1. Allow mirroring in tube and pipe
    Last Post: 2011-12-02, 09:55 PM
  2. Allow dimensions between tube & pipe route sketch lines if parallel
    Last Post: 2011-11-03, 02:13 AM
  3. Tube & Pipe/ Pipe Sections to work like Frame Generator on BOM
    Last Post: 2011-11-02, 08:51 PM
  4. Tube & Pipe Allow Tee's and Y sections in pipe routing
    Last Post: 2011-11-02, 07:13 PM
  5. Tube & Pipe Wishes
    By cbenner in forum Inventor Wish List
    Last Post: 2011-04-29, 02:03 PM
Tags for this Thread
