Thread: Plotting - setting lineweights
    2014-02
    20
    Default Plotting - setting lineweights
    I am creating a set of template drawings. As most of the layouts will be either 1:100 or 1:50 scale I assume that the correct place to determine the plot lineweight is not in the model but in the VPlineweight tab in the viewport layers property palette - so that I can create a 1:100 viewport and a 1:50 Viewport in the same drawing. Is this the way others control lineweight? I am using named plot style tables.Thanks.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Plotting - setting lineweights
    Lineweights don't work that way. The lines will plot the same width at 1:1000 as they do at 1:5. A polyline width will plot twice as wide at 1:50 as 1:100 though.
  1. Lineweights for Plotting
    By Sparky in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-09-27, 05:10 AM
  2. plotting lineweights
    By vanderloo5 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-06-22, 07:25 PM
  3. Setting up lineweights?
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-10-22, 08:46 PM
  4. hide lineweights when plotting
    By dgraue in forum ACA General
    Last Post: 2007-08-28, 12:00 AM
  5. Setting Lineweights in LT2005
    By CHRISR.88946 in forum AutoCAD LT - General
    Last Post: 2005-06-20, 03:16 PM
