Results 1 to 6 of 6
Thread: SCALELISTEDIT command is not functioning
    2013-12
    10
    Default SCALELISTEDIT command is not functioning
    AutoCAD2014
    Went to change my viewport scale, hit my predefined max at 1:180, need something along the lines of 1:200. Click viewport, click viewport scale, and then custom but the pop up screen does not happen, AutoCAD does not function and SCALELISTEDIT comes up in the command box. I need to figure out why the pop window is suddenly not coming up so I can add new viewport sizing.
    2013-12
    10
    Default Re: SCALELISTEDIT command is not functioning
    Ignore my post, found the trick to get the box back after posting my thread a similar thread was linked. For those that cant find the thread.
    Enter command, press ALT + SPACE BAR, command box will follow, select move, hover mouse over autocad screen.
    2013-12
    10
    OK so that brought the command box back, however now when I click 'ADD' the dialogue box as well as CAD do not function and the pop up window for this command do not follow, have to hit escape to unfreeze command. I have tried to edit viewport scales in both model and paper space and both have the same result. Does anyone know why this has happened. I should note that this started on its own, I did not do anything to CAD to make this happen.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Try switching to a different profile. I recommend making dated backup copies of your CUI that you can switch to if need be.
    Cairo - no, not Illinois
    5,069
    Quote Originally Posted by prowley459709 View Post
    try the Alt spacebar and M again -- sounds like that dialog is ending up off screen as well.
    2013-12
    10
    That was it, tried it before but nothing happened, shut everything other then CAD down and minimized it, fixed the issue. Now if I could get the text dialogue pop up box to move so its not popping up in the middle of the screen everytime that would be awesome
  1. 2012: Global Attribute Edit Command not functioning in AutoCAD 2012
    By alex.kolb in forum AutoCAD General
    Last Post: 2018-11-08, 09:47 PM
  2. 2013: Having trouble with the "scalelistedit command", no dialogue box appears.
    By mwellman303122 in forum AutoCAD General
    Last Post: 2012-09-14, 07:44 PM
  3. SCALELISTEDIT ERROR
    By gerit in forum AutoCAD General
    Last Post: 2009-04-16, 01:02 PM
  4. SCALELISTEDIT
    By ruth515 in forum AutoCAD General
    Last Post: 2009-02-14, 08:20 AM
