Thread: How do I disable Quick Properties?
    2014-04
    Danbury CT, USA
    5
    Default How do I disable Quick Properties?
    I have a coworker who's having issues with her Quick Properties. Anytime she clicks on a leader, the quick properties window pops up over the object she's trying to edit.We've tried turning the quick properties off (QPMODE = 0, Ctrl+Shift+P, going through the CUI, toggling it off with Drawing Status Bar Menu, purposely turning it on and then turning it off through the aforementioned methods) and we're both stumped.She doesn't have the QP icon on the status bar, so I'm not sure if that has something to do with it. She doesn't normally use the QP (she prefers the regular Properties window), so we're not quite certain how it was turned on in the first place.
    6,420
    Default Re: How do I disable Quick Properties?
    If it keeps coming back, make sure that she has a workspace active and and she has the workspace setting "Automatically save workspace changes" selected.
    LinkedIn
    2014-04
    Danbury CT, USA
    5
    Double-checked to be sure that is set to auto save, but it still keeps coming back.
    5,719
    Quote Originally Posted by CharcoalWraith View Post
    I have a coworker who's having issues with her Quick Properties. Anytime she clicks on a leader, the quick properties window pops up over the object she's trying to edit. We've tried turning the quick properties off (QPMODE = 0, Ctrl+Shift+P, going through the CUI, toggling it off with Drawing Status Bar Menu, purposely turning it on and then turning it off through the aforementioned methods) and we're both stumped.
    Have you tried modifying the Quick Properties in CUI Editor, specifically removing the MLeader component altogether?
    To display the Quick Properties button on the Status Bar... Right-click on the Status Bar, expand the Status Toggles menu, and select Quick Properties.
    2014-04
    Danbury CT, USA
    5
    This worked! Thank you so much!
    5,719
    You're welcome, CharcoalWraith; I'm happy to help.
    Cheers
  1. 2010: Properties and Quick Properties are gone from quick menu
    By daxxterrygreen822678 in forum AutoCAD LT - General
    Last Post: 2012-07-10, 08:56 PM
  2. 2012: Quick Properties - how do you disable
    By jschultz in forum AMEP General
    Last Post: 2012-02-17, 03:28 PM
  3. Quick Properties
    By LogoKevn in forum AutoCAD General
    Last Post: 2012-01-24, 10:45 PM
  4. 2011: Properties Window Auto Apply Disable?
    By jchamberlain in forum Revit - Platform
    Last Post: 2011-09-22, 06:02 PM
  5. Quick Properties
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2008-11-11, 12:56 PM
