Hi gile and sniper,
I have the bundle copied into the ApplicationPlugins subdirectory. So where do I go to snoop the (drawing's) database. In AutoCAD 2014 I right click on the drawing, select MgdDbg, then select Snoop Database, and this starts up the viewer which shows me the block data which I want to inspect. Shown below are the contents of the PackageContents.xml. Where on the AutoCAD 2015 menu do I go to snoop the (drawing's) database.
AndrewCode:<?xml version="1.0" encoding="utf-8"?> <ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="DWG MgdDBG" AppVersion="1.0.0" Description="Debugging tools for AutoCAD - MgdDBG" Author="Fenton Webb" Icon="./Contents/Resources/resource/Inspector.jpg" AppNameSpace="adn.exchange.autodesk.com" OnlineDocumentation=" " HelpFile="./Contents/Resources/helpfile.html" ProductCode="{DB35F952-289A-4453-A46D-B424A6FCFDFB}" UpgradeCode="{E5B78003-2D7B-490F-B947-65D804392151}" SupportedLocales="Enu"> <CompanyDetails Name="Autodesk" Phone=" " Url=" www.autodesk.com" Email=" adn.autodesk.com" /> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R18.2" SeriesMax="R20.0" /> <Components Description="AutoCAD 2012"> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*|AutoCAD" SeriesMin="R18.2" SeriesMax="R18.2" /> <ComponentEntry AppName="DWGMgdDBG" Version="1.0.0" ModuleName="./Contents/Resources/DWGMgdDbgSource/bin/DebugA2012/MgdDbg.dll" AppDescription="Debugging tools for AutoCAD - MgdDBG" LoadOnAutoCADStartup="True" /> </Components> <Components Description="AutoCAD 2013"> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*|AutoCAD" SeriesMin="R19.0" SeriesMax="R19.0" /> <ComponentEntry AppName="DWGMgdDBG" Version="1.0.0" ModuleName="./Contents/Resources/DWGMgdDbgSource/bin/DebugA2013/MgdDbg.dll" AppDescription="Debugging tools for AutoCAD - MgdDBG" LoadOnAutoCADStartup="True" /> </Components> <Components Description="AutoCAD 2014"> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*|AutoCAD" SeriesMin="R19.1" SeriesMax="R19.1" /> <ComponentEntry AppName="DWGMgdDBG" Version="1.0.0" ModuleName="./Contents/Resources/DWGMgdDbgSource/bin/DebugA2014/MgdDbg.dll" AppDescription="Debugging tools for AutoCAD - MgdDBG" LoadOnAutoCADStartup="True" /> </Components> <Components Description="AutoCAD 2015"> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*|AutoCAD" SeriesMin="R20.0" SeriesMax="R20.0" /> <ComponentEntry AppName="DWGMgdDBG" Version="1.0.0" ModuleName="./Contents/Resources/DWGMgdDbgSource/bin/DebugA2015/MgdDbg.dll" AppDescription="Debugging tools for AutoCAD - MgdDBG" LoadOnAutoCADStartup="True" /> </Components> </ApplicationPackage>
MgdDbg commands are only acccessed via the shortcut menu. There are no ribbon tabs, etc.
C:> ED WORKING.... ▒
And here we are in 2016.
I tried to use the supplied files, but when I loaded MgdDbg.sln from DWGMgdDbgSource into MVS2013Community,
I re-defined the references to AcCoreMgd,AcMgd,AcDbMgd in the MgdDbgA2015-project
and simply tried to re-build, but several errors (and 2 warnings ... not important , I think) were listed:
Even after reading the migration guide for ObjectArx2016 and .NET I couldn't make out what to do, it all just is over my head.Error 1 No overload for method 'GetDBModel' takes 0 arguments GraphicsSystem.cs 133 60 MgdDbgA2015
Error 2 No overload for method 'GetGUIDevice' takes 0 arguments GraphicsSystem.cs 134 62 MgdDbgA2015
Error 3 'Autodesk.AutoCAD.DatabaseServices.AbstractViewTableRecord' does not contain a definition for 'RenderMode' and no extension method 'RenderMode' accepting a first argument of type 'Autodesk.AutoCAD.DatabaseServices.AbstractViewTableRecord' could be found (are you missing a using directive or an assembly reference?) SymbolTable.cs 146 63 MgdDbgA2015
Error 4 'Autodesk.AutoCAD.GraphicsSystem.View' does not contain a definition for 'Mode' and no extension method 'Mode' accepting a first argument of type 'Autodesk.AutoCAD.GraphicsSystem.View' could be found (are you missing a using directive or an assembly reference?) GraphicsSystem.cs 166 57 MgdDbgA2015
Error 5 'Autodesk.AutoCAD.GraphicsSystem.Configuration' does not contain a definition for 'UseDisplayLists' and no extension method 'UseDisplayLists' accepting a first argument of type 'Autodesk.AutoCAD.GraphicsSystem.Configuration' could be found (are you missing a using directive or an assembly reference?) GraphicsSystem.cs 213 70 MgdDbgA2015
Warning 6 The variable 'intType' is assigned but its value is never used QueryEntTests.cs 277 23 MgdDbgA2015
Error 7 'Autodesk.AutoCAD.DatabaseServices.Database' does not contain a definition for 'IsEmr' and no extension method 'IsEmr' accepting a first argument of type 'Autodesk.AutoCAD.DatabaseServices.Database' could be found (are you missing a using directive or an assembly reference?) RxObject.cs 329 54 MgdDbgA2015
Warning 8 The variable 'intType' is assigned but its value is never used QueryEntTests.cs 343 23 MgdDbgA2015
Error 9 'Autodesk.AutoCAD.DatabaseServices.Viewport' does not contain a definition for 'RenderMode' and no extension method 'RenderMode' accepting a first argument of type 'Autodesk.AutoCAD.DatabaseServices.Viewport' could be found (are you missing a using directive or an assembly reference?) Entity.cs 1044 68 MgdDbgA2015
So, is there a new release from someone more experienced than me?
It *appears* that nobody at Autodesk has taken on the maintaining of this utility, since Fenton left ADN for his promotion.
Computer Specs:
That's a great idea, honestly - we just need to get *some* help from Autodesk on that project with each release, otherwise someone here in volunteerland needs to cull the SDK/API changes each-and-every-single release (for each vertical as well?).
Would be neat to provide/publish NuGet package as well.
Cheers
Computer Specs:
I'd love to, I really would, but just being honest - my job is literally working me to death, right now (and for the past +/- year, mind you, it's really not healthy to work this much).
As for language, C# is the only way to go for any project that's going to garner wide support for others to contribute, etc., IMHO.
Cheers
Computer Specs:
