I have a Test Port part and a Gasket in Inventor.
Is it possible to add this small assembly to the Content Center ?
It is possible but it would be better if you keep away of content center and setup your custom/company library folder.
I totally agree with BeKirra. Keep things simple.
Bekirra/Pierre...
Having used/customized the Content Center extensively, I cannot say I agree with you. There are many situations where publishing items to the CC is the preferred approach. Although I have found some mistakes in the OOTB content, one has much more control with custom items, especially if you want to control the iterations available for a part/assembly. CC can be, at times, the simplest approach. I would like to hear your rationale behind your answers, though.
I have not used/customized the CC extensively. I wonder what the percentage of users that modify the CC would be (great survey idea). In my company, I have little time to learn the full depth of the software's capabilities. I am sure that there are things I would love to use, but simply do not know they are there. Surely other users are in my situation.
I still recommend using a company/custom library to just about anyone using Inventor. I also recommend learning how to modify the CC in case you really need to do so.
I guess I'll be hitting the books to refresh my memory !
