Results 1 to 10 of 15
Thread: Summarizing all blocks by their name into a table or a list.
    2012-06
    96
    Default Summarizing all blocks by their name into a table or a list.
    Can someone help me figure out a way to summarize all blocks located in active paper space by their names and then create (somewhere on the sheet) a summary list organized by block name and quantity of each block.
    I know how to organize all of the blocks into a selection set, but I am stuck after that...please help.
    Thank you
    2010-06
    962
    Default Re: Summarizing all blocks by their name into a table or a list.
    Try this ...
    (defun c:test (/ ss l)
      ;;	Tharwat 22. May. 2014		;;
      (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 410 (getvar 'CTAB)))))
        ((lambda (i / sn nm it)
           (while (setq sn (ssname ss (setq i (1+ i))))
             (if (setq it (assoc (setq nm (vla-get-effectivename
                                            (vlax-ename->vla-object sn)
                                 l
               (setq l (subst (list (car it) (1+ (cadr it))) it l))
               (setq l (cons (list nm 1) l))
          -1
      (if l
        (progn
          (foreach x l
            (print x)
          (textscr)
      (princ)
    )(vl-load-com)
    2012-06
    96
    Wonderful, this code works...it prints to the screen, I'll just have to tweak the code to make it print a list or a table on the sheet somewhere in paper space.
    Thank you
    PS. Could you explain how this code works for newbies like myself.
    2010-06
    962
    Try this .
    (defun c:Test (/ WriteAndSet columns e ss l hgt inc ins rows p r tbl)
      ;;	Tharwat 23. May. 2014		;;
                                 l
          -1
      (if l
        (progn
          (setq hgt
                 (if
                   (zerop
                     (cdr
                       (assoc
                         40
                         (setq
                           e (entget (tblobjname "STYLE" (getvar 'textstyle)))
                    (* (getvar 'textsize) 2.0)
                    (* (cdr (assoc 40 e)) 2.0)
                columns 2
                r 2
          (if (setq ins (getpoint "\n Specify Table Location :"))
            (progn
              (setq
                tbl (vla-addtable
                      (vlax-get
                        (vla-get-activelayout
                          (vla-get-activedocument (vlax-get-acad-object))
                        'BLOCK
                      (vlax-3d-point ins)
                      (+ (length l) 2)
                      columns
                      (* hgt 1.5)
                      (* hgt 1.5)
              (setq inc -1)
              (repeat 2
                (vla-setcolumnwidth tbl (setq inc (1+ inc)) (* hgt 5.))
              (vla-setrowheight tbl 0 (* hgt 1.5))
              (vla-setrowheight tbl 1 (* hgt 1.5))
              (vla-settext
                tbl
                (strcat "Blocks Quantity")
              (vla-setcolumnwidth tbl 0 (* hgt 10.))
              (vla-setcolumnwidth tbl 1 (* hgt 4.5))
              (vla-settext tbl 1 0 "Block Name")
              (vla-settext tbl 1 1 "QTY")
          (defun WriteAndSet (col row string)
            (vla-settext tbl row col string)
            (vla-setcellalignment tbl row col acMiddleCenter)
          (foreach x l
            (WriteAndSet 0 r (car x))
            (WriteAndSet 1 r (cadr x))
            (setq r (1+ r))
      (princ)
    (vl-load-com)
    2012-06
    96
    Do you think the same can be done by using MTEXT or TEXT instead of blocks?
    2010-06
    962
    Quote Originally Posted by vladimir.karatsupa982899 View Post
    At the mean time , I can say yes but it depends on what you are after as long as you did not give enough information .
    Did not you try the last routine that I wrote just for you ?
    2012-06
    96
    Oh yes I did and it works beautifully!!!!!
    ....sorry I forgot to update you.
    As I think more about this...I don't think text would be a good idea, so never mind about the text.
    Thank you very much for the routine...it works like a champ
    2010-06
    962
    Excellent , happy to hear that and you are welcome anytime .
    2012-06
    96
    I wanted to refine my selection set...and got the following:
    (setq ss (ssget "X" (list '(0 . "INSERT")(8 . "Units")(2 . "UNIT_*")(67 . 1)(cons 410 (getvar "CTab")))))
    Please take a look at it and advise why do I recieve an (error: bad argument type: consp "Units")
    When I do this...
    (setq ss (ssget "X" '((0 . "INSERT")(8 . "Units")(2 . "UNIT_*")(67 . 1)(cons 410 (getvar "CTab")))))
    I get (error: bad SSGET list)
    2006-07
    Currently Vancouver BC
    47
    you can't use use (cons... under quote '(
    '( means read AS IS
    In your case you will have to use (list
    (setq ss (ssget "X" (list '(0 . "INSERT")'(8 . "Units")'(2 . "UNIT_*")'(67 . 1)(cons 410 (getvar "CTab")))))
  1. Sheet List Table
    By Steve Smith in forum AutoCAD Sheet Set Manager
    Last Post: 2014-06-30, 04:30 PM
  2. Table List for Non SS Drawings
    By CADdancer in forum AutoCAD Sheet Set Manager
    Last Post: 2010-01-29, 05:07 PM
  3. Replies: 1
    Last Post: 2006-12-12, 07:36 AM
  4. Replies: 1
    Last Post: 2006-10-13, 04:58 PM
  5. Sheet List Table
    By afortier in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-01, 10:40 AM
