Results 1 to 8 of 8
Thread: Reset ootb F4 to match F3
    2015-10
    Colorado Springs, CO
    369
    Default Reset ootb F4 to match F3
    Struggling here...
    I frequently fat finger the F4 key when trying to toggle my running snaps with F3. We don't work in 3D, and have no need for the 3D snaps.
    Thought it would be pretty easy to reset the F4 key, and it was. I simply copied the factory F3 macro to a new command and assigned it to the F4 key. Great. 'cept the F4 version clutters my command line
    F3 Returns:
    Command: <Osnap on>
    Command: <Osnap off>
    F4 Returns:
    Enter new value for OSMODE <16511>:
    Command:
    Enter new value for OSMODE <127>:
    Command:
    Any ideas?
    Tallahassee, FL USA
    3,658
    Default Re: Reset ootb F4 to match F3
    2015-10
    369
    I got the key doing what it's supposed to, just the output on the command line is different for some reason.... Might just be some autocad magic that can't be duplicated!
    Tallahassee, FL USA
    3,658
    Quote Originally Posted by Coloradomrg View Post
    Struggling here...
    F3 Returns:
    Command: <Osnap on>
    F4 Returns:
    Command:
    Command:
    Any ideas?
    Where did you find the Macro for F3 you used for F4? ^O has been the standard macro since I started with AutoCAD r12 back in 1994. Since switching to Windows standards the keyboard shortcut has been Ctrl+L, but ^O is still the macro.
    2015-10
    369
    Copied it from the temporary override keyboard shortcut for F3 in the CUI.
    ^P'_.osmode $M=$(if,$(and,$(getvar,osmode),16384),$(-,$(getvar,osmode),16384),$(+,$(getvar,osmode),16384))
    I'll try the simpler ^O and report back
    2015-10
    369
    ^O is for ortho mode...
    Command: <Ortho on>
    Command: <Ortho off>
    Tallahassee, FL USA
    3,658
    Oops, should be: ^F
    2015-10
    369
    Perfect, that did it! F3 and F4 now behave identically. Thank you
    Guess next time I'll get into my books (Still have an R13 textbook even!) instead of relying on google!
  1. 2014: OOTB Templates
    By wurschel in forum Revit Architecture - General
    Last Post: 2014-07-21, 01:46 PM
  2. OOTB Families
    By rudolfweyers346383 in forum Revit Architecture - General
    Last Post: 2011-06-13, 07:51 AM
  3. OOTB Urinal 3D.rfa
    By patricks in forum Revit Architecture - Families
    Last Post: 2010-11-15, 05:30 PM
  4. RVT OOTB
    By gwnelson in forum Revit Architecture - Families
    Last Post: 2010-11-12, 07:45 PM
  5. ootb wall tag
    By dmorin in forum Revit Architecture - General
    Last Post: 2010-04-23, 03:12 PM
