Hi, I'd like to sweep a column I made (actually modelled as a fin) in a project. I could do this on a case by case basis by importing the relevant geometry (as a 3d dwg) into the family editor and doing it there (as a nested family) but I'd like to know if I can do this directly in the project file I am working on. I'm thinking it would be more straight forward that way and I make updates or changes easier, ie I wouldn't have to go creating custom nested families each time.
Basically what I'm trying to do is get a column family with an angle instance parameter to sweep around the facade which is has partly curved and partly straight sections. I'd like to individually control the angle parameter so arraying is obviously out as is doing it as a railing plus the spacing controls get bit funky.
Can Revit be Rhino in this case??? Cheers, would love to know if there is a way....Marcello?
