Thread: Tracking down Text Styles
    2013-04
    Portland, Oregon
    36
    Default Tracking down Text Styles
    Is there an easy way inside of revit or with a third party add in that will allow me to track down non-office standard text styles and change type or remove???
    2002-09
    Madison, WI
    5,687
    Default Re: Tracking down Text Styles
    Only way I can think of it so place a piece of that text type, select all instance in project and change them.
    But this won't fix the offending text types within labels of a family.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    The key words are "easy way". No.
    I tend to save out the families that I know have text then open them one by one, changing as required, then load them back into the template. It's a pain, but typically it's just a one time pain that you can do within a couple hours once you get the repetition of the process figured out.
    2015-09
    481
    Quote Originally Posted by david_peterson View Post
    Also doesn't grab legend text styles, at least not in 2014 or previous
  1. Merge Text Styles ie LAYMRG but for text styles
    By dustin692884 in forum AutoLISP
    Last Post: 2018-05-01, 11:59 AM
  2. Tracking Dimension Styles
    By h.jobe in forum AutoCAD General
    Last Post: 2012-03-21, 10:49 PM
  3. layers, text styles, dim styles on tool palette
    By jledgewood in forum AutoCAD Customization
    Last Post: 2010-05-24, 03:30 PM
  4. Sharing standard Dimension styles, text styles, hatch patterns, etc
    By dhavalpatel_us337373 in forum AutoCAD General
    Last Post: 2007-02-02, 08:34 PM
  5. Setup Correct Layers,Dim Styles,Text Styles
    By rhayes.99001 in forum AutoLISP
    Last Post: 2007-01-23, 05:49 PM
