Thread: Revit Arch 2013 - Door Swing Question
    2012-04
    Pottsville, PA
    167
    Default Revit Arch 2013 - Door Swing Question
    Hi! I am creating a family of doors. I would like to be able to show the door swing at 45 deg and 90 deg. What step am I missing to make that happen. I am drawing the door swing in plan view with symbolic lines (over top of my reference lines. For some reason I cant get the lines to lock together.
    Thanks!
    Rob
    2012-04
    Pottsville, PA
    167
    Default Re: Revit Arch 2013 - Door Swing Question
    I got it working... I used the "pick line" tool and there is a check box to lock the lines...
    Rob
    2006-10
    15
    Hi Rob, glad you got it working.
    Just for your reference, Steve Stafford did a great tutorial on creating parametric doors that you might want to take a look at. I used it as a guide when I first started developing my set of doors.
    There's a part that covers making the parametric 2d door swing with a variable angle swing with step by step instructions. Here's the link...
    http://www.aecadvantage.com/BD21-1LMaster.pdf
  1. 2013: Revit Arch 2013 - Associated Level Question
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2014-06-27, 05:14 PM
  2. Revit Door Swing Line Type
    By birman in forum Revit Architecture - General
    Last Post: 2010-05-10, 01:47 PM
  3. Door Swing Elevation Lines - Revit 2008
    By jmarchese in forum Revit Architecture - Families
    Last Post: 2008-09-25, 09:04 PM
  4. Door family w/ curved swing new and straight swing existing
    By ericsson in forum Revit Architecture - General
    Last Post: 2007-12-19, 04:02 PM
  5. ADT Door Swing Display PROBLEM in Revit
    By agreven.109920 in forum Revit Architecture - General
    Last Post: 2006-04-12, 03:12 PM
Tags for this Thread
