Your getting a little help from PBJese here. See link where he helped me out here---->http://forums.augi.com/showthread.ph...pecific-layers
This is a start but it only pics up the points where the 2 layers cross.
(defun c:ROADIT (/ ss1 _39 p-cw p-hw ss1 e v)
(setq rl "CONFLICT")
(if (not (tblsearch "LAYER" rl )); check if layer duct is present
(command "-layer" "make" rl "color" 2 rl "") ; if not create the layer
( )) ; the layer exist, do nothing
(setq _3p (lambda (lst)
(if lst
(cons (list (car lst) (cadr lst) (caddr lst))
(_3p (cdddr lst))))))
(if (setq P-CW nil
P-HW nil
ss1 (ssget "a" '((0 . "LINE,LWPOLYLINE,POLYLINE") (8 . "BUILDING,ROAD"))
(progn
(repeat (setq i (sslength ss1))
(setq e (vlax-ename->vla-object (ssname ss1 (setq i (1- i)))))
(if (eq (vla-get-layer e) "BUILDING")
(setq P-CW (cons e P-CW))
(setq P-HW (cons e P-HW))))
(foreach itm P-CW
(foreach mti P-HW
(if
(setq v (vlax-invoke itm 'IntersectWith mti acExtendNone))
(foreach int (_3p v)
(command "circle" "non" int "d" 6)
(command "change" (entlast) "" "P" "LA" "CONFLICT" "")
(princ))
