Hi
i wanted to know if i can create a section view only on one view
with out going to other views and hiding the section
Hi
Hi,
Generally there are 2 ways to do it.
First, in the section properties you can select "Hide at scales coarser than" and specify the scale - it does work but it doesn't eliminate the problem 100%
Second, my preferred option is to create a Section Type for Site, building, detail, planning, presentation..... This way you can filter these easily from the views that you want and also it allows you to assign a view template for each section type and makes the workflow much faster.
I actually use the same technique for elevations and plans as well.
Maciej
