Results 1 to 6 of 6
Thread: Automatic Curb Return Grading
    Wish List Administration
    2011-08
    4,581
    Default Automatic Curb Return Grading
    Summary: Add the function of properly grading a Curb Return in the Intersection Wizard
    Description: The intersection Wizard currently puts a straight line solution into the kerb return profile. As has been discussed previously the expectation in some parts of the world is to provide quarter points and a vertical curve so that a complete solution is provided. This is essential in steep situations where the straight transition does not allow a reasonable solution. It also gives a neat looking set of contours.
    Given the simplicity of the solution can we get it programmed in please.
    Product and Feature: AutoCAD Civil 3D - Alignments
    Submitted By: Alec Tadman on 06/30/2014
    2011-08
    4,581
    Exclamation Re: Automatic Curb Return Grading
    2003-07
    561
    Default Re: Automatic Curb Return Grading
    Have a look at the 3rd party product Advanced Road Design running under CIV3D it does what you want
    2011-02
    5
    Quote Originally Posted by ahouston972454 View Post
    I have ARD but like all users I would like Autodesk to do the job properly and add the basic features not leave them out.
    2009-11
    5,719
    Have you considered simply editing the Curb Return Alignment's Profile (in Profile View)?
    Computer Specs:
    2011-02
    5
    Quote Originally Posted by BlackBox View Post
    Hi. As per the previous comment regarding the use of Advanced Road Design, the functionality provided by that package inserts an automatic kerb return and grading based on standard criteria.
    So when you do an intersection design and tell it to do a grading it automatically does the correct grading, not a straight line job like C3D does at the moment. And when you amend either of the roads forming an intersection and update it, the grading updates.
    So for good user functionality (that is available in other packages but embarrassingly for Autodesk not in Civil 3D) the proper kerb return grading function should be included as standard. The maths behind it is really simple so I am surprised Autodesk have not included it.
    If you have for example 40 intersections in your model, having to manually grade them and update them as changes are made is not particularly useful.
  1. 2014: Proper Curb Return Slope Labels
    By dpresley58437170 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2014-03-02, 10:39 PM
  2. Grading Automatic Updating
    Last Post: 2012-11-14, 01:08 PM
  3. Corridor Intersection Curb Return Problems
    By georgeh in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-05-03, 02:34 AM
  4. Intersection Wizard--Curb Return
    By raunelortiz659677 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-02-10, 04:25 AM
  5. Curb grading
    By suji_rash in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-01-08, 03:12 PM
