Thread: How t o highlight an element while the command is running
    2010-05
    13
    Default How t o highlight an element while the command is running
    My plugin will show a Window Form with different room properties listed on it. What I want is to highlight an room when I select this room from GUI. Is there any simple way to do it?
    The method mentioned in this blog (http://thebuildingcoder.typepad.com/...-elements.html) can highlight an element only after the Execute() function is finished. However, I want the element to be highlighted in between (i.e., Window Form GUI is still running and a room can be hilghlighted by selecting this room from this GUI)
    2012-09
    34
    Default Re: How t o highlight an element while the command is running
    You should be able to do something like this:
    Element elementToSelect;
    UIDocument uidoc;
    SelElementSet selElementSet = uidoc.Selection.Elements;
    //If you want to deselect all previously selected elements
    selElementSet.Clear();
    selElementSet.Insert(elementToSelect);
    uidoc.Selection.Elements = selElementSet;
    //If you want to show the element as well
    uidoc.ShowElements(elementToSelect);
    In 2015, it's done a little differently:
    ElementId idOfElementToSelect;
    UIDocument uidoc;
    uidoc.Selection.SetElementIds(new[] {idOfElementToSelect});
    uidoc.ShowElements(idOfElementToSelect);
    As far as I know, there is no restriction on highlighting the element while a command is running. The link you referenced is very old so the restriction must have been removed since then.
    2010-05
    13
    Thanks! I find ShowElements seems very slow. So I use boundingBoxXYZ and UIView class to show element in a specified range..
  1. 2014: how to select an element while Window form is running
    By kukuzry in forum Revit - API
    Last Post: 2014-07-16, 06:37 PM
  2. New Command - Highlight Overridden Labels
    Last Post: 2013-04-23, 02:15 PM
  3. 2011: HIGHLIGHT reverts to 0 after burst command?
    By stimmo520 in forum AutoCAD General
    Last Post: 2011-05-09, 01:07 PM
  4. Highlight Text From the Find and Replace Command
    Last Post: 2007-05-02, 05:12 PM
  5. Replies: 8
    Last Post: 2005-06-30, 02:32 PM
Tags for this Thread
