Thread: Site plan unwanted lines
    2013-04
    51
    Default Site plan unwanted lines
    Hi, In my site plan I have a topography with some unusual terraces, now I have these jagged lines that show up along with the topography in the view as shown in the attached photo. Is there any way I can turn these off?
    Actually I just went into Visibility graphics and turned them off, so cheers anyway
    2008-11
    Australia
    754
    Default Re: Site plan unwanted lines
    Would you mind posting the process you did to turn them off for anyone else that might stumble across the same problem? Cheers.
    2005-07
    Somewhere in the BIM world
    3,792
    Topography - Contours
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Many Revit objects have subcategories. As you discovered, topography has contours, triangulation and more. In VG, note the categories that have a plus mark. All of them open up and allow you to turn off certain subcategories.
    2013-04
    51
    Sure, I just went into Visibility Graphics and switched of all the subcategories under topography.
  1. Unwanted lines at printed sheets.
    By big T in forum Revit Architecture - General
    Last Post: 2012-01-09, 11:11 PM
  2. Building Out Lines in Site Plan
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-10-16, 12:50 PM
  3. Unwanted grid lines
    By Brian F. in forum Revit Architecture - General
    Last Post: 2005-01-21, 09:33 PM
  4. Site Plan and Property Lines
    By cgrover in forum Revit Architecture - General
    Last Post: 2004-10-28, 06:29 AM
  5. Unwanted lines in door openings
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-07-07, 04:43 PM
