When I place beam tag at start of beam it displays as question mark.
You need to provide more information please.
You have a beam placed in Revit and you place a beam tag and it displays a question mark?
Are the beam(s) and tags OOTB entitites?
What should the beam tag show?
Can you upload a sample of what you're talking about, like a small revit file?
And/or a screen shot?
This is simple, you haven't given the beam a number yet, depending on what your tag reads, this may either be entering something like "B1" into the mark, or comments fields.
If the field is blank, it will give a ? by default. I like to edit my tag so that the default says B? (if you edit the label you can change what it displays when there is no field filled out).
