Thread: Restore UCS North to pointing up.
    2011-03
    East Hampton, NY
    32
    Default Restore UCS North to pointing up.
    Hi All,
    This may be a simple question, but:
    I am working on a drawing that was converted to a .dwg file for use in AutoCAD 2014. The Y/X coordinates are pointing on an angle, thus pointing north to that angle. I would like to restore north so the view is pointing "up" in Model Space. What combination of commands would do that?
    Cairo - no, not Illinois
    5,069
    Default Re: Restore UCS North to pointing up.
    Is the world coordinate system current, or a user coordinate system? If the former, the PLAN command will get you there.
    in the upper right corner
    3,504
    Yes, to add to that, if the latter and it is a UCS (user coordinate system) and the "Y" axis is pointing to your desired north, PLAN will get you there too.
    Is this a civil project where the cad work is oriented to a global coordinate systyem in Model Space?
    The reason I ask is sometimes you need to be careful if Civil designers need to work on this, sometimes changing the WCS to a UCS can cause them problems if they don't know about it.
    Other related commands / topics are
    DVIEW > Twist
    Snapang
    WCS
    UCS
    Named Views
    Named UCS's
    2011-03
    East Hampton, NY
    32
    Thank you for your reply.
    No, Not a civil Engineer Project. Thanks for the heads up. My drawings are used for display purposes only, not surveys.
    The Orientation just changed by itself for me. I had UCSFollow on and created a hatch, and the view changed to due north. Done.
    I still don't know how to do it so I will need to practice UCS commands.
    Thank you for your help.
    - John
  1. The Moving Linked CAD file (Project North True North)
    By mkim in forum Revit Architecture - General
    Last Post: 2019-06-03, 08:49 PM
  2. 2015: Pipe annotation leader pointing
    By sandy03 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2015-05-18, 11:47 AM
  3. Revit 2013 True North and Project North Toggle
    By HWu397185 in forum Revit - Platform
    Last Post: 2013-07-11, 11:11 PM
  4. Set View so it is pointing North?
    By abid.tabassum in forum AutoCAD General
    Last Post: 2007-02-07, 04:51 AM
  5. Cool pointing device
    By cadkiller in forum Revit - Hardware & Operating Systems
    Last Post: 2005-09-13, 03:27 PM
