Thread: Disable dropdown tip bubbles.
    2011-02
    8
    Question Disable dropdown tip bubbles.
    so these are almost as bad as Clippy, trying to give me advice all the time. I can click the "dont show me this again", but that only prevents THAT tip from being displayed. I dont want another one ever... is there a way to disable these?
    9,805
    Default Re: Disable dropdown tip bubbles.
    If you are only referring to the InfoCenter, are you open to removing InfoCenter completely? I don't know of a way to kill the messages while leaving InfoCenter intact.
    If so, put this in your "acad.lsp" file (create it if needed), and restart AutoCAD twice.
    ;; Disable InfoCenter
    (vl-registry-write
      (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\InfoCenter")
      "InfoCenterOn"
    If you're referring to all tooltips, such as those that appear on commands in the Ribbon, etc. that is a different precedure.
    5,719
    (vl-registry-write
      "InfoCenterOn"
    Be mindful of vlax-Product-Key in newer versions, as it may not always be the same as vlax-User-Product-Key; linky.
    Cheers
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    To change other tooltip display options look at the Display tab in the Options command.
  1. Whats the new way for my dropdown menus??
    By cadmaster77 in forum AutoCAD General
    Last Post: 2012-09-20, 06:05 PM
  2. 2012: Properties dropdown
    By jonathanschade in forum Revit - Platform
    Last Post: 2012-08-10, 03:05 PM
  3. Need generic grid bubbles & section bubbles
    By paullee in forum Revit Structure - General
    Last Post: 2006-09-19, 08:03 PM
  4. Dropdown Database List
    By gapple in forum AutoCAD Customization
    Last Post: 2005-09-22, 09:34 PM
  5. grid bubbles and level bubbles
    By sopori in forum Revit Architecture - General
    Last Post: 2004-08-25, 11:33 PM
