Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: LISP routine to overwrite layer descriptions...
    2006-08
    Southern California
    52
    Question LISP routine to overwrite layer descriptions...
    I've done several searches for a commands and/or LISP routine to overwrite an existing layer description with the same layer and description found in another file.
    My process:
    I have several files containing standard layers that are being updated as information is processed (Casework, Equipment, Furniture, etc.). I insert these files, when updated, into several main files (Level 1, 2, 3, etc.) to add, delete or replace layers. The use of the layers is to control my blocks and their visibility through the layer manager; hide all Casework or hide all base cabinets that are 30" tall, etc. The layer description is important because it gives the user an understanding of what the layer is specifically used for; layer 'CW-30-BC B3' has a layer description of 'Casework: 30" - Base Cabinet - (11" & 30")'.
    Should this layer description need to be updated from 'Casework: 30" - Base Cabinet - (11" & 30")' to 'Casework: 30" - Base Cabinet - (12" & 28")' I would like to insert the file containing the correct layer descriptions and overwrite the current layer descriptions. The current 'insert' function only overwrites the layer name, however, the layer description remains unchanged.
    Note: Using the Design Center to add or overwrite layers, using Layer Translator (laytrans), or using Layer Standards (.dws) have only edited the layer name, and layer properties, these commands have not edited the layer description.
    Anything you can offer to get me started is greatly appreciated.
    2009-11
    5,719
    Default Re: LISP routine to overwrite layer descriptions...
    Quote Originally Posted by dortega4269 View Post
    I have several files containing standard layers that are being updated as information is processed (Casework, Equipment, Furniture, etc.). I insert these files, when updated, into several main files (Level 1, 2, 3, etc.) to add, delete or replace layers....
    Not that this couldn't be done with some custom code, but to get at the root issue here... If I understand you correctly, you're currently inserting your new template into your existing drawing(s)... What happens when you insert your existing drawing(s), into a new, empty drawing created from your new template?
    Cheers
    [Edit] - To save others from making duplicate responses:
    http://www.cadtutor.net/forum/showth...r-descriptions...
    http://www.theswamp.org/index.php?to...4528#msg524528
    Computer Specs:
    2006-08
    Southern California
    52
    Quote Originally Posted by BlackBox View Post
    Thanks for the quick reply BlackBox, the layer names would be overwritten/updated, however, due to the file size and 3D content, inserting the entire drawing into a new template takes several minutes and I would need to do this with several drawings. Not to mention I would be forced into inserting all of my xrefs again.
    Below are all of my layer templates. Each control several items using the predefined layers and layer descriptions.
    Thanks for the added links, great idea...
    Last edited by dortega4269; 2014-07-21 at 05:03 PM. Reason: added image and additional information
    2005-06
    in the upper right corner
    3,508
    Why not just write a master lisp routine that creates the layers with descriptions?
    Then simply run it in your drawing(s) and it will update to whatever you want?
    You could even set it up to run in an Acaddoc.lsp to do it automatically.
    2001-03
    Tallahassee, FL USA
    3,667
    Wouldn't a Standards (DWS) file take care of that without any coding?
    2005-06
    3,508
    Ahh yes good point! (didn't even think of that)
    That should work, if you have proper DWS files updated the way you want them, you could update the target drawings that way.
    Good call Tom.
    2009-11
    5,719
    ... the layer names would be overwritten/updated, however, due to the file size and 3D content, inserting the entire drawing into a new template takes several minutes and I would need to do this with several drawings.
    Correct, and that helps to explain why you opted not to follow the typical procedure; this old routine will (re-)create layers based on a source, regardless of if they already exist or not.
    Incorrect; inserting a drawing into another drawing includes any external references to the former.
    Cheers
    Computer Specs:
    2009-11
    5,719
    *Someone* didn't read the fine, red print in the OP.
    Computer Specs:
    2006-08
    Southern California
    52
    Not a bad idea tedg. I found the following 'simple' routine, but what if the layer existed and it needed to be overwritten?
    (defun c:dwt ()
    ; Layers
    (command "layer" "m" "purlin" "lt" "continuous" "" "c" "7" "" "")
    (command "layer" "m" "wp" "lt" "center" "" "c" "8" "" "")
    (command "layer" "m" "bolt" "lt" "continuous" "" "c" "6" "" "")
    (command "layer" "m" "bracing" "lt" "continuous" "" "c" "3" "" "")
    (command "layer" "m" "endwall" "lt" "continuous" "" "c" "1" "" "")
    (command "layer" "m" "mezzanine" "lt" "continuous" "" "c" "2" "" "")
    (command "layer" "m" "steel" "lt" "continuous" "" "c" "5" "" "")
    (command "-linetype" "load" "hidden" "" "yes" "" "")
    I also found this link which has tons of options...
    http://forums.autodesk.com/t5/Visual...p/td-p/3560508
    2009-11
    5,719
    See post #7 of this thread for a routine that does exactly this.
    Computer Specs:
  1. Special Layer Freeze LISP Routine
    By dbanker in forum AutoLISP
    Last Post: 2017-08-11, 12:32 PM
  2. Layer Color Change LISP Routine
    By guardianfiredesign774457 in forum AutoLISP
    Last Post: 2013-08-28, 05:08 AM
  3. Add layer command line to a lisp routine
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-02, 07:47 AM
  4. Layer creation lisp routine?
    By boeris9333 in forum AutoLISP
    Last Post: 2009-10-05, 11:24 AM
  5. Lisp routine help, Layer check problem
    By Craig.Baldie in forum AutoLISP
    Last Post: 2007-10-12, 06:27 AM
