Thread: changing default field value in archibus / sql
    2001-12
    St. Louis
    5,407
    Default changing default field value in archibus / sql
    I've created new fields in Archibus before, but, haven't done much modifying of existing fields.
    I need to modify the default value for a couple of my fields and the records save, but, when I run an update to my database schema, the ones that did not have a default already have saved fine, but, the ones that already had a default saved are failing.
    I'm not certain if this is an Archibus thing or a SQL thing. I checked my SQL Bible (just like I did with my AutoCAD Bible ) but, couldn't find applicable entries just flipping through the index and related chapters.
    Here's an excerpt of one of the errors:
     Field was changed, prepare the ALTER TABLE statement: space_use
    DROP INDEX LS._WA_SYS_00000001_385E379D
    DROP INDEX LS._WA_SYS_00000029_385E379D
    DROP INDEX LS._WA_SYS_00000031_385E379D
    DROP INDEX LS._WA_SYS_00000011_385E379D
    DROP INDEX LS._WA_SYS_00000023_385E379D
    DROP INDEX LS._WA_SYS_00000020_385E379D
    DROP INDEX LS._WA_SYS_00000018_385E379D
    DROP INDEX LS._WA_SYS_00000017_385E379D
    DROP INDEX LS._WA_SYS_00000015_385E379D
    DROP INDEX LS._WA_SYS_00000010_385E379D
    DROP INDEX LS._WA_SYS_0000000F_385E379D
    DROP INDEX LS._WA_SYS_00000025_385E379D
    DROP INDEX LS._WA_SYS_00000046_385E379D
    DROP INDEX LS._WA_SYS_00000048_385E379D
    Drop Default Value Constraint If Exists For SQLServer
    Drop Constraint If Exists For SQLServer
    Change Default Value For SQLServer
    This operation is postponed:
     ALTER TABLE ls ADD CONSTRAINT DF_ls_space_use_default  DEFAULT 'RETAIL' FOR space_use
    Executing the postponed Schema change
      Error details: Column already has a DEFAULT bound to it.
    Could not create constraint. See previous errors.
    Of course, now that I'm looking back, I thought maybe I should save without a default, then add a different default, but, it looks like the one case which my users wanted left blank failed when I tried to remove the default.
     ALTER TABLE cost_tran_recur ADD CONSTRAINT DF_cost_tran_recur_date_start_default  DEFAULT NULL FOR date_start
    I'd appreciate any advice or pointers to the right help file, etc, thanks!
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,407
    Default Re: changing default field value in archibus / sql
    Okay, so, I got my answer today.
    I spoke to my consultant in our regular meeting and happened to ask him about this.
    I'm still a noob with Archibus, so, when my local rep had taught me how to make field changes last winter, I'd been warned to use the settings as attached.
    BUT, if you want to replace a default, you have to tick the option to Re-create from Scratch (in the Update Table Structure group, see screencap below).
    You need to double and triple check that your values are valid (mine were selections from an enum list, so, obviously had to match one of the available options there), but, it went off without a hitch then.
    Thick Client
    WebCentral
    This will be something I'll need to keep tucked away in the back of my mind. It's not often I have to make a change like this
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Default field values
    By junkdiver in forum AutoCAD Fields
    Last Post: 2017-02-17, 01:06 PM
  2. Changing the Default Directory in a LSP
    By dlittle590601 in forum AutoLISP
    Last Post: 2014-03-13, 05:21 PM
  3. Changing default font
    By max in forum Revit Architecture - General
    Last Post: 2009-07-28, 03:40 PM
  4. Field changing color
    By cwjean76 in forum AutoCAD Fields
    Last Post: 2008-05-20, 01:39 PM
  5. Changing the Default Layer
    By jphillips.88936 in forum AutoCAD General
    Last Post: 2008-01-31, 02:49 PM
