Does 2015 do something different with the NEW command than 2014 does?
The exact same process I've always used to start up AutoCAD is not working in 2015.
It looks to me like ACADDOC.LSP is not getting loaded.
Here's the weird thing. If I do an OPEN on an existing DWG file, it works fine. But if I do a NEW, I don't get everything loaded.
Text Window from 2014:
Customization file loaded successfully. Customization Group: BWBR
Customization file loaded successfully. Customization Group: USER
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: CONTENTEXPLORER
Customization file loaded successfully. Customization Group: BLUEBEAM
Customization file loaded successfully. Customization Group: SKETCHUPIMPORTSKP
Customization file loaded successfully. Customization Group: APPMANAGER
Regenerating model.
AutoCAD menu utilities loaded.
LOADING ACADDOC.LSP
CodeBaseVersion 19
DosLib 19x64
DOSLib 9.0.1
Copyright © 1992-2012, Robert McNeel and Associates
AutoCAD Version 2014
BWBR Path C:/ACAD2013
Defining BWBR shortcuts
All layer filters have been deleted.
Plot command Redefined
AcadDoc.lsp loaded
Command: TILEMODE
Enter new value for TILEMODE <1>: 0
Regenerating layout.
Regenerating model - caching viewports.
Text Window from 2015 (New):
Regenerating model.
Express Tools Loaded*Cancel*
Command:
Command:
Command:
Text Window from 2015 (Open):
Opening an AutoCAD 2010/LT 2010 format file.
Regenerating model.
LOADING ACADDOC.LSP
CodeBaseVersion 20
DosLib 20x64
DOSLib 9.0.1
Copyright © 1992-2014, Robert McNeel and Associates
AutoCAD Version 2015
AcadDoc.lsp loaded
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
Command:
So, like I said, I suspect ACADDOC.LSP is not getting loaded when I do a NEW (or QNEW), but it used to do it in 2014, and it does do it in 2015 with OPEN. Just not with NEW.
I've tried a few (princ) statements, but I can't tell where that *Cancel* is coming from. It seems to crash before I can tell where it is.
Any help is appreciated.
