Thread: Parameter not available to Slab Edge category
    2009-06
    Madison, WI
    26
    Default Parameter not available to Slab Edge category
    In the following sample file there's two shared parameters and they are assigned to all categories.
    https://www.dropbox.com/s/ojbx6yuo9u...0available.rvt
    For some reason 'DRT_DH_Options' is available to a slab edge, but the other parameter 'POP Options' is not available. Both parameters are applied similarly.
    Anyone run across this before?
    Thanks, Ryan
    2009-06
    Madison, WI
    26
    Default Re: Parameter not available to Slab Edge category
  1. Floor slab edge thickenings to align and slope with slab
    Last Post: 2015-09-09, 05:24 AM
  2. Why does this slab edge offset prevent it from joining to a floor slab?
    Last Post: 2010-10-25, 09:49 PM
  3. slab-on-grade with gravel and thickened slab edge joining
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-11-23, 04:04 PM
  4. Slab Edge Profile not loading under Floor-Slab Edge
    By John Anderson in forum Revit Architecture - General
    Last Post: 2008-06-16, 05:44 PM
  5. Floor Slab Edge host sweep type on a sloped slab
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-02-17, 07:47 AM
