Thread: How to fix a corrupted file?
    2013-03
    165
    Default How to fix a corrupted file?
    I believe my file is corrupted and therefore the model is completely in wireframe now.
    I have decided to transfer the whole entire model into another pristine file. I honestly cant figure out what I should do but this. Please let me know if there is a better way.
    The first thing I did was to transfer project standards into the "virgin" file and create the phases as in the old file.
    I believe I need to recreate all the levels and views as well. If there is an easier way to make the transfers please advise.
    For instance would there be an easier way to transfer all the schedules?
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Default Re: How to fix a corrupted file?
    Sounds unlikely. Do you have a subscription account and have you sent the file to Autodesk?
    I don't think you need to recreate the levels. When you bind a Revit link it will ask you if you want to copy the levels. But I've played it safe and recreated them to be on the safe side.
    What have you done to fix the file? There is stuff you can do.
    2005-07
    Somewhere in the BIM world
    3,792
    Did you try on a different computer? Seems to be more like a hardware problem then a corruption if you can work in the file.
    2002-09
    Madison, WI
    5,687
    Really dumb question here. You mention everything is in "Wireframe" now so you think it's corrupt. You didn't happen to simply change the view setting did you? From say hidden line to wireframe?
    2013-03
    165
    Quote Originally Posted by Duncan Lithgow View Post
    Hi Duncan,
    I've tried purging the files but it still does not fix the problem.
    When you bind a Revit link, dont you have to explode the file afterwards. I havent thought of this one yet.
    What are the lists of stuff I can do to fix?
    2013-03
    165
    I'd like to answer my own question incase anyone else runs into this annoying problem. I deleted the view. I first renamed the 3D to "corrupted" and then deleted it.
  1. Corrupted Revit File
    By tomansill747521 in forum Revit Architecture - General
    Last Post: 2017-01-03, 03:11 PM
  2. 2012: Help with Corrupted CAD file
    By RACEMONEY183686 in forum AutoCAD General
    Last Post: 2012-11-20, 11:37 PM
  3. apj file corrupted
    By asandli in forum ACA General
    Last Post: 2007-05-02, 02:21 PM
  4. Replies: 1
    Last Post: 2007-03-26, 08:14 AM
  5. Help! Central File corrupted
    By katiel in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-05-24, 03:23 AM
