Thread: CW Sliding Opened Door
    2012-07
    Manchester, UK
    132
    Question CW Sliding Opened Door
    Hello, I am trying to create a CW Sliding Opened door but am experiencing some challenges when I actually try to "open" it.
    When doing the extrusions constrained to the Template's RPs the family flexes fine. Adjusting itself to the CW Panel size.
    But if I try to transpose it to the side, so that I can show the door opened, the new width does not seem to flex. But this happens only when loaded in the project. It works fine inside the Family Editor.
    Please see attached file.
    I kept a dummy door panel to test the "opened" version of it, while keeping the other panel inside the CW dimensions.
    File attached.
    Help appreciated.
    Many thanks in advance.
    J
    DOR-CW Sliding2Pan_a.rfa
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: CW Sliding Opened Door
    My only suggestion to you is that you create the opening panel as a separate family and nest it into the door family. It will make your life easier and will allow you greater control and flexibility over the opening. I probably wouldn't replace the existing panel geometry but control it's visibility based on whether the sliding panel is open or not.
    Is this for visualization purposes?
    2012-07
    Manchester, UK
    132
    Yes. Just for visualization purposes.
    So, you are saying I would be better off having 2 door panels (opened + closed) with a visibility parameter to choose on whether I would like the door to show open or closed?
    I will give it a try with using the nested family too.
    Thank you.
    J
  1. Sliding Pocket Door
    By d_miyasaki1895 in forum Revit Architecture - Families
    Last Post: 2011-03-06, 05:00 PM
  2. Sliding door arrows
    By nextvkin in forum Revit Architecture - Families
    Last Post: 2008-03-22, 12:18 AM
  3. Sliding glass door
    By tjhernacki in forum Revit Architecture - General
    Last Post: 2007-06-21, 07:36 PM
  4. Sliding door
    By Dereck67591 in forum Revit Architecture - Families
    Last Post: 2005-02-18, 08:32 AM
  5. Sliding-Closet Door
    By Steven Campbell in forum Revit Architecture - Families
    Last Post: 2004-02-18, 11:04 PM
Tags for this Thread
