Thread: Snap overrides coordinate entry and grip edits
    2003-08
    99
    Question Snap overrides coordinate entry and grip edits
    With osnap on, I cannot grip edit objects using coordinate or directional entry without objects snapping to nearest snap point. I have to turn osnap off (<F3>) before I can use coordinates or directions to edit objects. How can I turn this override off?
    2003-08
    99
    Default Re: Snap overrides coordinate entry and grip edits
    Found solution on another thread. Reset OSNAPCOORD variable to <1> keyboard entry overrides osnap settings. Thanks AUGI forums!
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by jrb63 View Post
    Thank YOU for posting the solution for future searchers who run across this.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. 2015: Grip Edits
    By tim_newsome in forum AutoCAD General
    Last Post: 2014-09-09, 02:25 PM
  2. 2012: -PAN with coordinate entry not working as expected
    By Steve_Bennett in forum AutoCAD General
    Last Post: 2014-06-19, 07:11 PM
  3. Replies: 3
    Last Post: 2012-05-15, 06:44 PM
  4. Direct coordinate entry
    Last Post: 2008-12-15, 04:23 PM
  5. coordinate entry variable precision
    By Aston in forum AutoCAD Tips & Tricks
    Last Post: 2008-05-24, 01:06 PM
