Why doesn't this work in a macro?
Using AutoCAD 2014
Code:^C^C(setq CE (getvar "CMDECHO"))(setvar "CMDECHO" 0)(setq DIST (getdist "Enter distance or <first point>:"))(setq DISTT (/ DIST 2))(command "offset" DISTT)(setvar "CMDECHO" CE)
Using AutoCAD 2014
Because it is a lisp routine... not a macro.
Set your routine to a command. For example:
Save the lisp file in your support file search path.Code:(DEFUN C:o2 () (setq CE (getvar "CMDECHO")) (setvar "CMDECHO" 0) (setq DIST (getdist "Enter distance or <first point>:")) (setq DISTT (/ DIST 2)) (command "offset" DISTT) (setvar "CMDECHO" CE) )
Make sure the lisp routine is loaded.
Then your macro can be:
Code:^C^Co2;
Computer Specs:
R.K. McSwain | CAD Panacea |
You might also want to look into the PAUSE keyword/function.
[Edit] - Or, given the simplicity of the macro, simply adding an OFFSET Command alias.
Computer Specs:
Didn't know that... learned something new You guys are good for that around here.
Computer Specs:
You can specify commands to be called under certain keystroke aliases. I.E. I have the command MATCHPROP to QR such that when I type QR it knows to run matchprop. You can access the command alias interface by typing ALIAS at the command line. It's a critical tool for drafting and speed.
HTH
What "Mr. Box" is suggesting (I believe)...
This macro basically does what the "offset" command does**, so why don't you create an alias (shorter version of the command) of offset to do this?
Some people use "Alias Editor" but I go right into the Acad.pgp file to create/edit my command alias'.
**The offset command allows either a typed in distance or you pick a distance (2 points on screen) which seems to be what you're doing in the macro.
Just a thought
BTW, my alias for "offset" is simply the letter "o", you can't get much quicker than:
(command "o" <pick two points> <select line> <pick side you want it to offset> done!)
