Results 1 to 7 of 7
Thread: TEXT THICKNESS IN A TITLEBLOCK
    2005-04
    Saintlouis Missouri
    529
    Default TEXT THICKNESS IN A TITLEBLOCK
    Good morning. The line with WDG# PROJ # I would like to hive the text thicker. The office wants this font but I can not seem to be able to do anything about it. Is this correct? The font is simplex. Is there another font that is very similar but thicker? I have it in Bold already as well. Hope to hear something right away since I am printing in a hour. If, not no worries since it is a progress set anyway. thanks all
    2005-06
    in the upper right corner
    3,507
    Default Re: TEXT THICKNESS IN A TITLEBLOCK
    Revit doesn't play well with SHX fonts.
    Can you find a TTF font that is similar that you can use?
    There is a Romans.ttf that is close to Romans.shx in AutoCAD, and you can make it bold if needed for lineweight.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    We switched to Arial....everyone has it and there are different versions of it too. Simplex and RomanS is too skinny.
    BTW, Revit only uses TTF fonts....SHX are AutoCAD only.
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    2005-04
    Saintlouis Missouri
    529
    Thanks. I will get online and look for the ttfonts and compare
    2006-10
    CdA, ID
    1,533
    Quote Originally Posted by harkeychad View Post
    Don't even need to get online....
    Control Panel --> Fonts --> Preview
    But you can try this site too.... http://www.typetester.org/
    2005-07
    Somewhere in the BIM world
    3,792
    Just keep in mind that if you use a "custom" font everyone you share the file with needs to have it install also...
    2005-04
    Saintlouis Missouri
    529
    sweet. did not know that the fonts where under the control panel
  1. Toggle Text off and on in a Titleblock.
    By scowsert in forum Revit Architecture - General
    Last Post: 2008-07-04, 02:20 PM
  2. Text on Titleblock
    By marisa.miller in forum Revit Architecture - General
    Last Post: 2007-06-18, 10:20 PM
  3. Constraining Text on a titleblock?
    By CADMama in forum Revit Architecture - General
    Last Post: 2006-08-31, 07:45 AM
  4. Titleblock and text confusion
    By dalewww in forum Revit Architecture - General
    Last Post: 2004-12-02, 02:58 PM
  5. titleblock text
    By sfaust in forum Revit Architecture - Families
    Last Post: 2004-01-29, 03:56 PM
