Thread: Light leaks on rendering
    2014-03
    16
    Angry Light leaks on rendering
    I´m experiencing some issues with lighting on renders. There are some glitches where it should be just reflexes (at the ceiling in the attached image). I´ve lost a lot of hours of work trying to solve the problem, with no results. What am i doing wrong? Does anyone knows some solution? Tks
    2014-03
    16
    Default Re: Light leaks on rendering
    I´m still on that issue. Does anyone knows something i might do about?EP-1092-224-verde.rvt_2015-Feb-06_08-46-18PM-000__Pool.jpg
    2014-03
    16
    Till now, a reasonable workaround i found is to create an array of Studio Lights (Revit families library), and don´t use the Self Illumination feature, but Transparency/Translucence instead.
  1. 2014: Rendering a Nested Light Fixture
    By Mandy_Jo in forum Revit Architecture - Families
    Last Post: 2015-07-08, 03:57 PM
  2. 2014: Light fixture does not produce light in rendering
    By ctc in forum Revit Architecture - Families
    Last Post: 2014-04-11, 07:56 PM
  3. Rendering Area Lighting - Light Only
    By mjward1 in forum Revit - Rendering
    Last Post: 2009-06-09, 07:35 AM
  4. Problems controlling Sun & Artifical Light rendering function
    By eballantine in forum Revit Architecture - General
    Last Post: 2009-01-19, 07:44 PM
  5. Rendering and Light effects
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2008-11-06, 06:47 PM
