Results 1 to 1 of 1
Thread: attribute array in dynamic block
    2014-10
    Default attribute array in dynamic block
    Hello Sirs!
    I would like to array some attributes which are inside a dynamic block. It is same like a table.
    I started based on a finded file (SectionSample.dwg and eyample.dwg) but I can array only the lines without the attributes.
    I don't know how can I array they like in the sample dwg or example.dwg (see Drawing1.dwg)
    How can change the first letter (A, B, C,D....) like in the example.dwg?
    Could anybody help me?
  1. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  2. Array attributes in a dynamic block
    By aquihugo in forum Dynamic Blocks - Technical
    Last Post: 2011-03-28, 02:46 PM
  3. Array Dynamic Block
    By gedwilson in forum Dynamic Blocks - Technical
    Last Post: 2009-12-21, 02:06 PM
  4. Array attribute in dynamic block?
    By frankowen2 in forum Dynamic Blocks - Technical
    Last Post: 2005-06-07, 01:58 AM
Tags for this Thread
