Hi All,
I’ve modelled a roof across a building approximately 150m x 150m with a cranked beam system at 1.65m centres. I’ve attached some images below of the model. Between the centres there is a bracing system that was modelled to node out at the beam (the analytical line for the beam is 63mm off centre), however when I copied the bracing around the model between the centres, I noticed that the bracing wasn’t nodeing out at the beam and it was nodeing out 0.4mm away from the beam. This is now causing a problem when exporting the model into SCIA as the whole roof system isn’t connecting.
Is there any tool that will automatically connect the nodes? Or any tolerances that can be adjusted so that the nodes connect? Any suggestions would be very helpful. Thank You
Regards,
George
