Hello to all,
I am having some difficulties in getting my plan to show openings in a wall correctly, when the opening was created using the wall opening tool. This particular plan has been set up to display slightly different than how we would normally show a 2nd floor framing plan. For clarity reasons the walls above have a VG override setting to be shown has hidden and on a lower pen weight than normal so that other items stand out. The problem that I am having is that the walls below are not showing the opening jambs in the wall. I have tried adjusting the view range and the only settings that seem to work correctly end up showing the slab on grade below as well. If I adjust the wall transparency in the VG overrides then my walls above become solid, which I believe is showing the bottom edge (sill plate lines) of the wall above. Using the linework tool isn't an option for the walls above due to the nature of the project, that would cause a lot more of unwanted work. I really don't want to have to remodel all the walls below as separate walls that stop at each opening or by adjusting the wall profile in an elevation view since there are many walls that would have to adjusted. I'm not sure of what other options I have at this point and any suggestions would be greatly appreciated. I've attached a pdf with a couple of screen shots of just 1 example wall that is having this problem.
Kyle
