Hi.
Is it possibile write a routine to export a drawing or block in dxf aama?
Thanks
Hi.
Thanks
If you have the dxf-amma file format specifications, and the ability to write code that AutoCAD can execute, then I'm sure it can be done.
Are you wanting to do this yourself or hire someone to do it?
R.K. McSwain | CAD Panacea |
Hi,
attached specification file dxf aama.
I try to understand something and then I start to write a few lines of code.
thanks
Hi,
attached an example of dxf aama.
Unfortunately npon I can open it, how can I be able to open the file to see how it's done?
thanks
bb
Hi,
I was able to open the file in DXF aama corel draw, and then I exported in DXF.
Enclosed is the new dxf that I got and that can be opened in AutoCAD.
Unfortunately corel draw has transformed the polyline to a spline .....
However, the files you can figure out how it should be set to a dxf file aama.
I hope someone can help me aa go on ....
Thanks
bb
