The number of dividers is not the problem it is the array in elevation/section will always be the length of the "Array Length" in the family when it was loaded. I have now put two lines in the plan that match up with the shelf lines so it virtually disappears in plan. I can dimension that in plan and they all show up properly. In elevation/section I can see the dividers and if I dimension them they are always what the Array Length is in the family that was loaded last. You can try something to see what I mean.
Pun in a family with a 6 on the end of it, that means a 60" shelf, several dividers.
Check the distance of the array in elevation/section.
open the family and change the Shelf Length to 24"
Reload the family - just load into project - skip the catalog
check the dimension of the array in elevation and it will be 12"
I should say that our projects are not in feet and inches. Set your project to Fractional Inches before you run this test.
I am on the same build here David.
