Good Afternoon,
I had seen a couple of similar threads to this, but so far no clear solutions.
Autocad Architecture 2015. I have various apartment units that need to appear in various configurations around the building, so each unit is it's own block (demising walls are just dumb lines). These blocks get rotated and mirrored in different places.
Similar to other users, I'm finding that editing and saving the block will break much of the wall intersection and door cutting cleanup. Mirroring was mentioned a possible culprit, but I've confirmed this on blocks with no mirrored instances (as well as with only one instance). The previously suggested OBJRELUPDATE seems to help a small amount, but much of the block remains broken.
Any further ideas for this sort of thing?
Edit: Upon further inspection, it appears that restarting Autocad entirely will fix any currently broken blocks, but more show up as I continue to work, so that's obviously not a long term (or convenient!) solution.
