Thread: Horizontal Shaft
    Wish List Administration
    2011-08
    4,581
    Default Horisontal shaft
    Summary: I wish for the ability to add a horisontal shaft that can go through more than one wall.
    Description: A horisontal shaft that works like the vertikal but you place it on a wall, and can extrend it several meters so it goes through more than one wall. For when you need to create the same size holes in several walls for installations that goes through the whole house.
    Product and Feature: Revit Structure - Walls
    Submitted By: Jenny Stucki on 10/23/2014
    2005-08
    Netherlands, Rotterdam
    19
    Default Re: Horizontal Shaft
    You can do that with a void in place or void family
    2007-04
    12
    I have created a tutorial which shows how to create a Structural Opening that will replace a shaft opening, this can be used in any plane or a face of a component. This will also cut other members such as Foundations, Structural Framing etc.
    https://revitstructureblog.wordpress...ning-families/
  1. 2014: shaft openings
    By lnicholson676970 in forum ACA General
    Last Post: 2014-09-30, 02:36 PM
  2. 2013: Model Horizontal Shaft - Best Method - Revit Architecture
    By Limbatus in forum Revit Architecture - General
    Last Post: 2013-02-14, 12:29 PM
  3. 2012: Edit Shaft
    By wpeacock in forum Inventor - General
    Last Post: 2011-08-24, 04:38 PM
  4. Demolish Shaft
    By wenterline868055 in forum Revit Architecture - General
    Last Post: 2011-04-14, 01:02 PM
  5. Shaft Tool
    By wenterline868055 in forum Revit - Platform
    Last Post: 2011-02-04, 03:15 PM
