Description: When using the measure tools allow the use of the Grids and levels as a snapping point.
How Used: Being able to measure how far off of a gridline a piece of duct/pipe/object is. Start the measure command, select the gridline you are wanting to measure off of then select the face of the geometry that you are needing to know the distance of.
Feature Affinity: Dimensions and Measure Tools
