Hi everyone,
I am looking for a lisp that will change the colors, linetypes, etc of the original file to match the colors, linetypes, etc of the file that it is xref into.
Thank
Hi everyone,
Thank
Try this. It matches color, linetype, lineweight and plottable status.
Code:(defun c:setxlayer ( / xlayer ; ename of layer to be evaluate xl ; xlayer dxf lis xname ; Xref layer name cname ; current dwg layer name matching xname clayer ; cname's ename cl ; current dwg layer's dxf list ) (while (setq xlayer (tblnext "layer" (not xlayer))) (if (= 16 (logand 16 (cdr (assoc 70 (setq xl (entget (tblobjname "layer" (cdr (assoc 2 xlayer))))))))) (progn (setq xname (cdr (assoc 2 xl)) cname (substr xname (+ 2 (vl-string-position 124 xname)))) (if (setq clayer (tblsearch "layer" cname)) (progn (setq cl (entget (tblobjname "layer" (cdr (assoc 2 clayer))))) (entmod (mapcar (function (lambda (a) (cond ((= (car a) 62) (cons 62 (if (minusp (cdr a)) (- (abs (cdr (assoc 62 cl)))) (abs (cdr (assoc 62 cl))) ) )) ((member (car a) '(6 290 370)) (assoc (car a) cl)) (T a) ) ) ) xl ) ) ) ) ) ) ) (princ) )
Layer transparency? I saw it coming... Hoped OP doesn't need it.
Code:(defun c:setxlayer ( / xlayer ; ename of layer to be evaluate xl ; xlayer dxf lis xname ; Xref layer name cname ; current dwg layer name matching xname clayer ; cname's ename cl ; current dwg layer's dxf list layer_transparency ) (while (setq xlayer (tblnext "layer" (not xlayer))) (if (= 16 (logand 16 (cdr (assoc 70 (setq xl (entget (tblobjname "layer" (cdr (assoc 2 xlayer))))))))) (progn (setq xname (cdr (assoc 2 xl)) cname (substr xname (+ 2 (vl-string-position 124 xname)))) (if (setq clayer (tblsearch "layer" cname)) (progn (setq cl (entget (tblobjname "layer" (cdr (assoc 2 clayer))) '("AcCmTransparency"))) (if (setq layer_transparency (assoc -3 cl)) (entmod (append xl (list layer_transparency))) ) (entmod (mapcar (function (lambda (a) (cond ((= (car a) 62) (cons 62 (if (minusp (cdr a)) (- (abs (cdr (assoc 62 cl)))) (abs (cdr (assoc 62 cl))) ) )) ((member (car a) '(6 290 370)) (assoc (car a) cl)) (T a) ) ) ) xl ) ) ) ) ) ) ) (princ) )
Incorrect; to clarify, see the bottom of this post.
You've done well so far, add only what you're willing to.
Cheers
