Results 1 to 1 of 1
Thread: Turning on WYSIWYG Text Editor
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Turning on WYSIWYG Text Editor
    Some of you have asked how to hyperlink, and do other 'text' based operations in the Fourms. It didn't occur to me until today, but many of you probably have not turned on this option! The Forums have a WYSIWYG Text editor, which must be set by each user.
    Go to Control Panel link (in the gray menu bar above the posts, on the left.)
    Then click on Edit Options
    On the Options screen, scroll to the bottom to Miscellaneous Options
    For the Message Editor Interface, change the pull-down to Enhanced Interface - Full WYSIWYG Editing
    Click Save Changes buttom at the bottom.
    Now your Text Editor should have a set of buttons along the top of the text window.
    Hope that helps!
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
  1. Text not WYSIWYG
    By Revitator in forum Revit Architecture - General
    Last Post: 2013-01-24, 10:17 AM
  2. Multiline Text Editor truncating imported text file
    By zellingj in forum AutoCAD General
    Last Post: 2006-12-06, 09:28 PM
