Thread: Artifacts in my Renders (but not in 360 cloud rendering
    2010-09
    43
    Default Artifacts in my Renders (but not in 360 cloud rendering
    So the first image what a scene looks like when I render on my computer. The second one is renders on 360 cloud.
    I had been rending on my PC earlier and I had not problems all of a sudden it's unusable. Any thoughts?
    2016-02
    Sydney, Australia
    512
    Default Re: Artifacts in my Renders (but not in 360 cloud rendering
    It could be a graphics card problem, and a re-boot should fix it, or a new driver for it. I noticed your ambient lighting is off on the PC image & not the 360 cloud. That might be compounding the error.
    2010-09
    43
    How did you notice that? And how can I turn it back on?
    Also what's weird is that it wasn't doing it earlier then just all of a sudden. I tried rendering it at work with better computer (quadro card) and I got the same weird results
    2010-09
    43
    Found the answer to my issue.
    http://www.reddit.com/r/Revit/commen...ghting/clsbc0e
    It was the IES file I was using.I tried a different file and it worked fine.
    Also It rendered fine on the cloud because it uses a better render engine than revit. It was not my computer. I tried rendering in 3DSM and it was fine.
    2016-02
    Sydney, Australia
    512
    Ambient lighting is controlled in the Graphic Display Options Dialogue box, under Lighting.
  1. 2013: Cloud vs. local rendering - cloud looks TERRIBLE!vd
    By patricks in forum Revit - Rendering
    Last Post: 2022-08-17, 10:52 PM
  2. 2016: Cloud Rendering
    By jwallgren498618 in forum Revit Architecture - General
    Last Post: 2016-01-12, 07:20 PM
  3. 2014: cloud rendering
    By scottyermer in forum Revit - Platform
    Last Post: 2013-12-26, 06:50 AM
  4. Cloud Rendering help
    By jsteinhauer in forum Revit - Rendering
    Last Post: 2012-12-07, 09:59 PM
  5. Stone Rendering Material renders gray...
    By twiceroadsfool in forum Revit - Rendering
    Last Post: 2008-06-06, 03:08 PM
