Results 1 to 10 of 13
Thread: Retaining variable values for use after saving and closing
    2008-11
    13
    Default Retaining variable values for use after saving and closing
    I've written a couple of routines for numbering terminals and wires in an electrical schematic circuit. How can I retain the values of variables for use again after the drawing has been saved and then re-opened. For example a variable numVal would have a value of 101 (the last wire number used). When I re-open the drawing I would like to retrieve that value and continue numbering.
    2010-06
    962
    Default Re: Retaining variable values for use after saving and closing
    Your explanations are not clear enough at least to me . So more info is needed .
    Timothy, don't know if you mean AutoCAD so I'm going to give it a shot ... I had to create a lisp routine since some of the variables reset every time I close and re-open. I call it Variables.lsp and in it I have the following:
    (setvar 'HPDRAWORDER 1)
    (setvar 'DYNMODE 3)
    (setvar 'FIELDEVAL 16)
    (setvar 'DXEVAL 0)
    (setvar 'OSMODE 63)
    Make sure to put it in your Startup Suite
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    You could look into dictionary records to store your data to be reused for a per drawing variables. You could look into using the registry for a drawing independent variable.
    2008-11
    13
    AutoCAD 2014. The routines are written using Autolisp. In the code I create a variable called numVal. This variable is incremented after each pick point places a number in the drawing in a while loop...(setq numVal (+ numVal numInc))... The routine works very well in the drawing session. What I am trying to achieve is to retain the value of numVal so that it can be re-used the next time the drawing is opened. Currently, all variables are reset when the drawing is re-opened.
    2008-11
    13
    It's user defined variables that I am trying to retain rather than system variables. I have a copy of "Inside Autolisp" (J. Smith and R. Gesner New Riders Publishing 1989 ). It refers to a routine called PVAR.lsp. It provides functions for creating personal variable system which can retain variable values in a drawings LTYPE table. So I'm playing with that at the moment. It should be noted that I am very new programming.
    2002-01
    jUSt Here (a lot)
    9,106
    Again, searching these forums for the methods previously mentioned will help you find the code samples you are looking to implement.
    2009-11
    5,719
    Quote Originally Posted by Imkie View Post
    Firstly, I'd recommend that you read David Stein's The Visual LISP Developer's Bible:
    As for your plight, there are only a few ways to achieve what you're after, and you're going to have to decide which is best.
    It is unfortunate that you're using 2014 in lieu of 2015, and the latter introduces a simple means by which to add custom System Variables as shown here, with a working example here.
    As you cannot use this new functionality in 2014, you're relegated to storing either externally (i.e., external file, registry, etc.), or to internal database (i.e., NOD [named object dictionary], etc.). It sounds as though you're after the latter, so you may want to read up on the differences between Dictionaries and XRecords for saving data, let alone their LISP and Visual LISP counterparts.
    Cheers
    Computer Specs:
    2008-11
    13
    Thank you for the links and the book idea.
    Earth
    9,805
    Do you want to store the data in the DWG file or somewhere else such as the users local hard drive or a network drive?
    See also:
    http://www.eng-tips.com/faqs.cfm?fid=175
    http://www.cadtutor.net/forum/archiv...p/t-34829.html
    R.K. McSwain | CAD Panacea |
  1. Replies: 3
    Last Post: 2015-07-15, 03:35 AM
  2. Help With Variable DB Increment Values
    By CADdancer in forum Dynamic Blocks - Technical
    Last Post: 2014-10-02, 12:33 PM
  3. Replies: 6
    Last Post: 2009-01-06, 04:08 PM
  4. Multiple Values in a single variable?
    By rmcelvain.103137 in forum Revit Structure - Families
    Last Post: 2007-02-02, 02:32 PM
  5. Scale a Derived Part With variable X,, Y & Z Values
    Last Post: 2006-08-01, 03:39 PM
