Thread: pre-engineered wood roof & floor trusses
    Wish List Administration
    2011-08
    4,581
    Default pre-engineered wood roof & floor trusses
    Summary: need to add pre-engineered wood trusses to structural framing
    Description: There needs to be a better way to add pre-engineered wood trusses and be able to adjust top and bottom chord slopes.
    Product and Feature: Revit Structure - 3rd party structural analysis link
    Submitted By: Brian Zack on 11/13/2014
    2015-12
    19
    Default Re: pre-engineered wood roof & floor trusses
    What is needed is a truss family template that is responsive to the beam system command.
    The beam and brace template is unwieldy for truss profiles.
    The complex beams and trusses do not respond to the beam system command. Neither does the truss template.
    What I have done is use the complex beam and truss template for trusses. I draw the components as extrusions from the front view lying in the front/back plane. It is the simplest way to cut the ends to fit at joints. It is entirely a manual process. I have to located them on plan individually. A big problem is opening the family and making changes. The result is members coming apart or can't create model. I presume that locking sections together in the first version is the cause of this fragmentation.
    Yes, pre-engineered trusses spaced like joists/rafters needs a lot of help.
  1. 2015: pre-engineered wood trusses
    By tkunsman in forum Revit Structure - General
    Last Post: 2015-07-16, 06:20 PM
  2. 4x2 Wood Floor Trusses
    By jsr13 in forum Revit Structure - General
    Last Post: 2012-08-15, 02:14 PM
  3. Wood Floor Trusses Sharing a Bearing Wall
    By dbumgarner in forum Revit Structure - General
    Last Post: 2011-06-28, 06:05 PM
  4. Engineered Roof Structure - DWF
    By jay.80870 in forum ACA/AMEP Gallery
    Last Post: 2009-03-04, 03:26 PM
  5. wood trusses
    By BMerritt in forum ACA General
    Last Post: 2007-04-22, 09:56 PM
