Thread: Release a .dll with a WinForm
    Default Release a .dll with a WinForm
    Hello, I've created a .dll with a WinForm and Multiple classes in VS 2012. I released it,however , when I used the .dll in another computer with Netload command nothing happened. But, with its release folder it worked. How can I release the .dll so I used only it? Thank you, Mohsen
    2007-08
    202
    Default Re: Release a .dll with a WinForm
    Hi,
    Basically, when you compile a .NET solution, one DLL is created for each project contained in the solution.
    So, if you define all your classes in the same project, they will be embeded in the same DLL.
    If your project references some 'home made' DLLs these ones have to be in the same folder as the compiled DLL.
  1. 2014: WPF user control instead of a Winform
    By drewj in forum Revit - API
    Last Post: 2013-11-14, 08:04 PM
  2. Next Release
    By dzatto in forum AutoCAD General
    Last Post: 2008-01-28, 12:38 PM
  3. What release was the first with SSM?
    By Maverick91 in forum AutoCAD Sheet Set Manager
    Last Post: 2008-01-17, 01:13 PM
  4. Release Dates & Release Codenames
    By Buffeldrek in forum Inventor - General
    Last Post: 2006-09-22, 02:19 PM
Tags for this Thread
