Results 1 to 1 of 1
Thread: UT104-1: Bringing Mobile Field Updates into AutoCAD
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default UT104-1: Bringing Mobile Field Updates into AutoCAD
    Instructor: Glenn Vlass
    Class Description: Today, more and more utilities/telecoms are deploying mobile solutions and are often tasked to “do more with less”. Meeting the needs of both the field and office personnel can be a difficult task, especially when it comes to bringing the mobile field updates back into AutoCAD Map 3D. In this class, typical problems will be discussed along with best practices of how other companies have gone about solving this problem. This presentation will explore the requirements to efficiently collect asset management data using Map 3D and CartoPac Mobile along with how to define a data workflow and understand how data is to be moved between AutoCAD Map 3D and CartoPac Mobile. This presentation will help you understand key issues and determine how to plan for a mobile implementation. Already have a mobile application in the field? Learn best practices, improve your efficiency, and increase your ROI.
  1. Replies: 7
    Last Post: 2012-10-17, 08:47 PM
  2. 2013: Bringing in Polylines & Splines from Autocad Drawings
    By Argyll9846 in forum Inventor - General
    Last Post: 2012-06-14, 10:26 PM
  3. Bringing .bas files into AutoCad
    By houstonvett in forum AutoCAD General
    Last Post: 2007-08-10, 07:54 PM
  4. AutoCAD LT to AutoCAD Full version updates justification
    By pferreira in forum CAD Management - General
    Last Post: 2006-06-21, 02:39 PM
