Results 1 to 1 of 1
Thread: Wood hatch pattern looks good in section, bad in plan
    2014-02
    Default Wood hatch pattern looks good in section, bad in plan
    Hello,
    I am encountering an issue where the various wood patterns in the project look correct in section but not in plan. The patterns are a 'drafting' type and it seems to only be a problem affecting the various wood patterns, but some other custom/imported hatch patterns look correct regardless of view orientation. Rotating the detail item/filled region in plan does not change anything. This is a really frustrating issue. Can anyone help?
    I've attached two images of a specific detail item where the hatch appears incorrectly (although this affects any filled region using the hatch) and I've also attached the hatch pattern.
    plan:
    section:
    Thanks!
  1. Spanish tile hatch pattern - roof plan
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2009-12-11, 12:54 AM
  2. Hatch wall pattern is not visible in plan
    By ricardo.226710 in forum Revit Architecture - General
    Last Post: 2009-08-18, 05:18 PM
  3. In need of Wood Hatch Pattern
    By sifuentes in forum AutoCAD General
    Last Post: 2004-12-28, 10:22 PM
  4. Cut Pattern in Plan Not Section
    By aaronrumple in forum Revit - FAQ (Read only)
    Last Post: 2004-10-30, 02:23 PM
