Thread: UVW mapping
    2014-10
    Raceland, Louisiana
    3
    Default UVW mapping
    When creating a UVW mapping for an object I am unable to fit the gizmo to the object. I can't manipulate it to fit the object. What am I missing?
    2015-05
    Edinburgh, Scotland
    4
    Default Re: UVW mapping
    UVW mapping is based on the XYZ planes - choose the mapping type that best fits the object you are mapping and apply a UVW Mapping Modifier. To modify the UVW gizmo - just select the modifier as a subobject in the editor list - the distortions you can do are pretty limited (like move rotate scale) but if you need more control over mapping look for tutorials utilising the Unwrap UVW Utility - this gives you an output of the object spread out on a 2D plane that you can paint up in Photoshop (or whatever) << this technique is more commonly used for character or organic objects. Remember there are also tiling/scaling/offset options available within the Material Editor as well - but this can be problematic if you are using the same material on multiple objects - but you can always create copies.
    2014-10
    Raceland, Louisiana
    3
    Thanks Blinkinlight
  1. Mapping a parameter
    By elaforge in forum Revit MEP - Families
    Last Post: 2010-08-27, 04:11 PM
  2. Mapping
    By mAnOO in forum AutoCAD General
    Last Post: 2010-04-18, 11:27 AM
  3. Mapping Layers?
    By awarren in forum Inventor - General
    Last Post: 2008-08-20, 12:58 PM
  4. UV Mapping
    By Jit in forum Revit - Rendering
    Last Post: 2004-04-01, 06:29 PM
