Hello
I'm learining to create revit families. I made a tee. However in my tee it is possible to have higher branch than the hight of the tee. What am I doing wrong?
Hello
The simplest answer is because the heights of the different sections are decided by 2 different parameters, If you set both heights to the same parameter then they will match.
If I'm honest i probably wouldn't use sweeps to make that family. You could pretty simply use an extrusion in the Tee shape and set the depth as the height parameter you want.
