I am trying to delete several corrupt topologies but cannot load them. Is there a way to delete these corrupt items? The error message I am getting is "duplicated topology id number".
Go to Map - Topologies - Administration and you should be able to manipulate them as needed.
nstien,
I think in some older versions of Map the 'Delete' option was not available unless the topo was loaded... and if the topo is corrupted, sometimes it cannot be loaded...
In Map 3D 2005, the option is available to delete topologies without loading them...
Not sure if this info helps or not?
Warren M
nstein, if this is the case and you don't have 2005, post the drawing and some one with 2005 can delete the topologies for you.Originally Posted by warren.medernach
Glenn Pope
Civil Designer/CAD Manager
River City Engineering
AutoCAD Civil 3D 2011 Ver. 3
Windows 7 Pro 64bit
I explode MTEXT.
At the command line type MAPTOPOADMIN then D for delete then the name of the topology you want to delete. This was the only way in older versions of map to delete a corrupt topology.
In the future, don't copy objects that are part of a topology. This is what caused your error.
Scott D. Daniel
GIS Analyst
Ruekert · Mielke
W233 N2080 Ridgeview Parkway
Waukesha, WI 53188
(262) 542-5733
(262) 542-5631 Fax
sdaniel@Ruekert-Mielke.com
http://www.ruekert-mielke.com
